Date/Time: Sat, 23 Nov 2024 04:40:03 +0000
SC Historical Data ES#
View Count: 1519
[2013-06-19 22:28:53] |
User88901 - Posts: 33 |
Hi, when I am connected to SC historical Intraday Futures data and I bring up the symbol ES# it shows the data but I would like it to be more detailed for volume profile like it is when I bring up a 60 min chart. Will I just have to use the Intraday chart to get this more detailed data and if so how do I back adjust September with June so that it will display volume correctly as I have been having a hard time figuring it out. I tried the continuous contract button and tried to join the data manually and adjust but nothing worked correctly.
Date Time Of Last Edit: 2013-06-20 02:59:38
[2013-06-20 03:41:56] |
You need to use an Intraday chart set to 1 day per bar. The most relevant help topic related to this is: http://www.sierrachart.com/index.php?l=doc/helpdetails13.html Sierra Chart does have the ability to Adjust Data: http://www.sierrachart.com/index.php?l=doc/doc_AdjustingData.html This functionality does work properly, but we do not provide technical help with the results. This is your responsibility. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-20 03:43:23
