Date/Time: Wed, 25 Dec 2024 04:36:00 +0000
How to remove the [M] near symbol?
View Count: 988
[2015-11-13 08:29:44] |
Alexey A Sidorovitch - Posts: 9 |
This is not critical but quite annoying for me. All the charts are having this [M] sign near the symbol. When it is located in the upper left corner of the chart it is ok. But I am having multiple sheets in the chartbook, so this sign on the bottom of the chart near symbol name becomes pointless and obtrusive (esp. when switching between charts). I just want to see the symbol there and the timeframe like it was before during all the years I am using Sierra. Thanks
[2015-11-13 08:58:34] |
This will be solved in the next release coming out before Monday.
[2015-11-15 20:26:02] |
Good to know this, thank you.
[2015-11-16 16:58:28] |
This is now solved. Update Sierra Chart with Help >> Download Prerelease. Here are instructions: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-16 19:12:02] |
Thank you! No more [M]s.
