Date/Time: Wed, 25 Dec 2024 02:19:00 +0000
Alert Condition For Bill Williams Fractals
View Count: 1554
[2015-11-13 06:07:53] |
boogybren - Posts: 9 |
I am currently using Bill Williams Fractals. It is ID6 and SG1 for short arrow and SG2 for long arrow. I have reviewed the alert documentation and couldn't see anything for alerting when the arrow appears. I've tested a handful of different formulas with no success. What is the syntax I would use? Brenden |
[2015-11-13 18:05:27] |
Normally the formula would be SG1>0. But the problem is that study does not set a nonzero value at the last bar in the chart in its Subgraph. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-13 19:56:38] |
Sawtooth - Posts: 4142 |
Since the Bill Williams Fractals study paints the triangle some bars after its marked position, but never at the same bar, this formula would catch the alerts within 3 bars: OR(SG1[-1]>0,SG1[-2]>0,SG1[-3]>0,SG2[-1]>0,SG2[-2]>0,SG2[-3]>0) Date Time Of Last Edit: 2015-11-14 04:20:12
[2015-11-14 01:39:00] |
Thank you @tomgilb. I will give this a go and see if I can get it to work.
