Date/Time: Wed, 25 Dec 2024 02:02:50 +0000
[User Discussion] - CountDown Timer Question
View Count: 1041
[2015-11-12 12:37:02] |
User316362 - Posts: 210 |
I was wondering if there is a way to "CountUP" instead od down. I'm aware the CountdownValue uses the "GetLatestBarCountdownAsInteger" for the value that is presented in Text. Is there a similar call that could be used for a countdown. Or a perhaps a different question would be how to get the Total Bar count (Tic Setting e.g. 3600 per bar) and the GetLatestBarCountdownAsInteger could be subtracted. Actually it would be good if the study had a choice of counting up OR down. Date Time Of Last Edit: 2015-11-12 13:04:27
[2015-11-12 20:23:38] |
In the case of a chart are based upon a certain Number of Trades, just simply add the Number of Trades study to the chart. This will give you a count of the number of trades as they increase.
