Date/Time: Thu, 26 Dec 2024 04:14:23 +0000
1324
View Count: 909
[2015-11-12 11:34:57] |
startledbymoth - Posts: 39 |
Everytime I start SC I get the following message: -Version 1324 is available. To download, select Help >> Download Current Version. Refer to the What Is New page for the new features and improvements. Twice, I have selected Help >> Download Current Version. I exit when prompted. Yet when I start SC again, I get the same message. Selecting Help >> About, I am told I am running Version 1307. I have downloaded current versions before and never had this problem. Please be aware that 1324 does not download as designed, and advise. |
[2015-11-12 18:54:10] |
There really should not be any problem with this. Do this again and before you exit from Sierra Chart provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-07 12:38:23] |
I got no email prompt and only just saw this response. I TOTALLY AGREE "THERE REALLY SHOULD NOT BE ANY PROBLEM WITH THIS." I no longer receive the advisement of an available uptdate. Instead, now, when I choose >> Help >> Download Current Version (Old Spreadsheets) I get the following Message Log Software version: 1307 | 2015-12-07 07:27:03 Uses Old Spreadsheets | 2015-12-07 07:27:03 Usage end date: 2015-12-20 | 2015-12-07 07:27:03 Enabled for: Advanced Features. | 2015-12-07 07:27:03 Enabled for: Advanced Features 2. | 2015-12-07 07:27:03 Enabled for: Sierra Chart Historical Data Service. | 2015-12-07 07:27:03 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-12-07 07:27:03 Current selected Data/Trading service: Rithmic Trading | 2015-12-07 07:27:03 Chart Update Interval: 500 | 2015-12-07 07:27:03 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-12-07 07:27:03 2015-12-07 07:27:03 Local computer time | 2015-12-07 07:27:03 2015-12-07 12:27:03 Local computer time in UTC | 2015-12-07 07:27:03 2015-12-07 07:27:03 Local computer time in SC Time Zone | 2015-12-07 07:27:03 2015-12-07 12:27:03 Server time in UTC | 2015-12-07 07:27:03 Local computer UTC time and Server UTC time difference: 1 seconds. | 2015-12-07 07:27:03 Program path: C:\SierraChart\ | 2015-12-07 07:27:03 Data Files path: C:\SierraChart\Data\ | 2015-12-07 07:27:03 OS Version Number: 6.1 | 2015-12-07 07:27:03 Locale Information: C | 2015-12-07 07:27:03 Checking for new symbol settings for rim | 2015-12-07 07:27:03 Symbol settings are up-to-date for rim | 2015-12-07 07:27:04 Rithmic Trading | Port for executable: 50243 | 2015-12-07 07:27:08 Listening socket (820), port 50243 | Closed. | 2015-12-07 07:27:08 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-12-07 07:27:08 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50243 | 2015-12-07 07:27:10 Socket (4) | Connected. | 2015-12-07 07:27:10 Rithmic Trading | Connected to server. | 2015-12-07 07:27:10 Rithmic Trading | Sending logon request message. | 2015-12-07 07:27:10 Rithmic Trading | Starting the connection process to data and trading service. | 2015-12-07 07:27:10 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-12-07 07:27:10 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-12-07 07:27:10 Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-12-07 07:27:11 Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2015-12-07 07:27:11 Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-12-07 07:27:12 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-12-07 07:27:12 Rithmic Trading | subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2015-12-07 07:27:12 Rithmic Trading | Server Alert: PnL Connection Opened | 2015-12-07 07:27:12 Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-12-07 07:27:12 Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-12-07 07:27:13 Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-12-07 07:27:13 Rithmic Trading | Server Name: SC DTC Bridge. | 2015-12-07 07:27:13 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2015-12-07 07:27:13 Rithmic Trading | Successfully connected. IB='OptimusFutures'. | 2015-12-07 07:27:13 Rithmic Trading | Trading is supported. | 2015-12-07 07:27:13 Rithmic Trading | Order cancel and replace is supported. | 2015-12-07 07:27:13 Rithmic Trading | Connected to data and trading server. | 2015-12-07 07:27:13 Rithmic Trading | OCO Orders supported. | 2015-12-07 07:27:13 Rithmic Trading | Received unknown message type from local socket. Type = 601 | 2015-12-07 07:27:18 Date rule based rollover from ESZ5-CME to next contract occurs at 2015-12-10. | 2015-12-07 07:27:44 Checking Intraday data file for symbol ESZ5-CME for the date range from 2015-09-10 to 0. | 2015-12-07 07:27:44 Checking Daily data file for symbol ESZ15 for the date range from 2015-09-10 to 2015-12-07. | 2015-12-07 07:27:44 ESZ5-CME [CB] 30 Min #4 | Price data for daily data file ESZ15.dly. Date: 2015-09-10, Price: 1939.75. Date: 2015-12-07, Price: 2091.5 | 2015-12-07 07:27:44 ESZ5-CME [CB] 30 Min #4 | Symbols used for continuous contract chart: | 2015-12-07 07:27:44 ESZ15 | 2015-12-07 07:27:44 ESZ5-CME [CB] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2015-12-07 07:27:44 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-12-07 07:27:44 Date rule based rollover from ESM5-CME to next contract occurs at 2015-06-11. | 2015-12-07 07:27:44 Date rule based rollover from ESU5-CME to next contract occurs at 2015-09-10. | 2015-12-07 07:27:44 Date rule based rollover from ESZ5-CME to next contract occurs at 2015-12-10. | 2015-12-07 07:27:44 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-12-07 07:27:44 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-12-07 07:27:44 Checking Intraday data file for symbol ESM5-CME for the date range from 2015-03-12 to 2015-06-11. | 2015-12-07 07:27:44 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-06-11. | 2015-12-07 07:27:44 Checking Intraday data file for symbol ESU5-CME for the date range from 2015-06-11 to 2015-09-10. | 2015-12-07 07:27:44 Checking Daily data file for symbol ESU15 for the date range from 2015-06-11 to 2015-09-10. | 2015-12-07 07:27:44 Checking Intraday data file for symbol ESZ5-CME for the date range from 2015-09-10 to 0. | 2015-12-07 07:27:44 Checking Daily data file for symbol ESZ15 for the date range from 2015-09-10 to 2015-12-07. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9 | Price data for daily data file ESZ15.dly. Date: 2015-09-10, Price: 1939.75. Date: 2015-12-07, Price: 2091.5 | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9 | Price data for daily data file ESU15.dly. Date: 2015-06-11, Price: 2101.5. Date: 2015-09-09, Price: 1942.75 | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9 | Price data for daily data file ESM15.dly. Date: 2015-03-12, Price: 2056.5. Date: 2015-06-10, Price: 2107 | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9 | Price data for daily data file ESH15.dly. Date: 2014-12-11, Price: 2024. Date: 2015-03-11, Price: 2039.5 | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-12-07 07:27:44 ESH15 | 2015-12-07 07:27:44 ESM15 | 2015-12-07 07:27:44 ESU15 | 2015-12-07 07:27:44 ESZ15 | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: ESH5-CME Open price on 2015-03-12 is 2042. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: ESM5-CME Open price on 2015-03-12 is 2034.75. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: ESH5-CME price difference to ESM5-CME is -7.25. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: ESM5-CME Open price on 2015-06-11 is 2106. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: ESU5-CME Open price on 2015-06-11 is 2098.5. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: ESM5-CME price difference to ESU5-CME is -7.5. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: ESU5-CME Open price on 2015-09-10 is 1943.75. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: ESZ5-CME Open price on 2015-09-10 is 1934.75. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: ESU5-CME price difference to ESZ5-CME is -9. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: Back adjust amount for symbol ESH5-CME is -23.75. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: Back adjust amount for symbol ESM5-CME is -16.5. | 2015-12-07 07:27:44 ESZ5-CME [CB] 1 Min #9: Back adjust amount for symbol ESU5-CME is -9. | 2015-12-07 07:27:44 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-12-07 07:27:44 * Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-12-07 07:27:44 Date rule based rollover from ESM5-CME to next contract occurs at 2015-06-11. | 2015-12-07 07:27:44 Date rule based rollover from ESU5-CME to next contract occurs at 2015-09-10. | 2015-12-07 07:27:44 Date rule based rollover from ESZ5-CME to next contract occurs at 2015-12-10. | 2015-12-07 07:27:44 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-12-07 07:27:44 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-12-07 07:27:44 Checking Intraday data file for symbol ESM5-CME for the date range from 2015-03-12 to 2015-06-11. | 2015-12-07 07:27:44 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-06-11. | 2015-12-07 07:27:44 Checking Intraday data file for symbol ESU5-CME for the date range from 2015-06-11 to 2015-09-10. | 2015-12-07 07:27:44 Checking Daily data file for symbol ESU15 for the date range from 2015-06-11 to 2015-09-10. | 2015-12-07 07:27:44 Checking Intraday data file for symbol ESZ5-CME for the date range from 2015-09-10 to 0. | 2015-12-07 07:27:44 Checking Daily data file for symbol ESZ15 for the date range from 2015-09-10 to 2015-12-07. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6 | Price data for daily data file ESZ15.dly. Date: 2015-09-10, Price: 1939.75. Date: 2015-12-07, Price: 2091.5 | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6 | Price data for daily data file ESU15.dly. Date: 2015-06-11, Price: 2101.5. Date: 2015-09-09, Price: 1942.75 | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6 | Price data for daily data file ESM15.dly. Date: 2015-03-12, Price: 2056.5. Date: 2015-06-10, Price: 2107 | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6 | Price data for daily data file ESH15.dly. Date: 2014-12-11, Price: 2024. Date: 2015-03-11, Price: 2039.5 | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6 | Symbols used for continuous contract chart: | 2015-12-07 07:27:44 ESH15 | 2015-12-07 07:27:44 ESM15 | 2015-12-07 07:27:44 ESU15 | 2015-12-07 07:27:44 ESZ15 | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: ESH5-CME Open price on 2015-03-12 is 2042. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: ESM5-CME Open price on 2015-03-12 is 2034.75. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: ESH5-CME price difference to ESM5-CME is -7.25. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: ESM5-CME Open price on 2015-06-11 is 2106. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: ESU5-CME Open price on 2015-06-11 is 2098.5. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: ESM5-CME price difference to ESU5-CME is -7.5. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: ESU5-CME Open price on 2015-09-10 is 1943.75. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: ESZ5-CME Open price on 2015-09-10 is 1934.75. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: ESU5-CME price difference to ESZ5-CME is -9. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: Back adjust amount for symbol ESH5-CME is -23.75. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: Back adjust amount for symbol ESM5-CME is -16.5. | 2015-12-07 07:27:44 ESZ5-CME [CB] 10 Min #6: Back adjust amount for symbol ESU5-CME is -9. | 2015-12-07 07:27:44 Date rule based rollover from ESZ5-CME to next contract occurs at 2015-12-10. | 2015-12-07 07:27:45 Checking Intraday data file for symbol ESZ5-CME for the date range from 2015-09-10 to 0. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESZ15 for the date range from 2015-09-10 to 2015-12-07. | 2015-12-07 07:27:45 ESZ5-CME [CB] 1 Min #17 | Price data for daily data file ESZ15.dly. Date: 2015-09-10, Price: 1939.75. Date: 2015-12-07, Price: 2091.5 | 2015-12-07 07:27:45 ESZ5-CME [CB] 1 Min #17 | Symbols used for continuous contract chart: | 2015-12-07 07:27:45 ESZ15 | 2015-12-07 07:27:45 ESZ5-CME [CB] 1 Min #17: Performing continuous futures contract back adjustment calculations. | 2015-12-07 07:27:45 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-12-07 07:27:45 * Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-12-07 07:27:45 Date rule based rollover from ESM5-CME to next contract occurs at 2015-06-11. | 2015-12-07 07:27:45 Date rule based rollover from ESU5-CME to next contract occurs at 2015-09-10. | 2015-12-07 07:27:45 Date rule based rollover from ESZ5-CME to next contract occurs at 2015-12-10. | 2015-12-07 07:27:45 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-12-07 07:27:45 Checking Intraday data file for symbol ESM5-CME for the date range from 2015-03-12 to 2015-06-11. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-06-11. | 2015-12-07 07:27:45 Checking Intraday data file for symbol ESU5-CME for the date range from 2015-06-11 to 2015-09-10. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESU15 for the date range from 2015-06-11 to 2015-09-10. | 2015-12-07 07:27:45 Checking Intraday data file for symbol ESZ5-CME for the date range from 2015-09-10 to 0. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESZ15 for the date range from 2015-09-10 to 2015-12-07. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18 | Price data for daily data file ESZ15.dly. Date: 2015-09-10, Price: 1939.75. Date: 2015-12-07, Price: 2091.5 | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18 | Price data for daily data file ESU15.dly. Date: 2015-06-11, Price: 2101.5. Date: 2015-09-09, Price: 1942.75 | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18 | Price data for daily data file ESM15.dly. Date: 2015-03-12, Price: 2056.5. Date: 2015-06-10, Price: 2107 | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18 | Price data for daily data file ESH15.dly. Date: 2014-12-11, Price: 2024. Date: 2015-03-11, Price: 2039.5 | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18 | Symbols used for continuous contract chart: | 2015-12-07 07:27:45 ESH15 | 2015-12-07 07:27:45 ESM15 | 2015-12-07 07:27:45 ESU15 | 2015-12-07 07:27:45 ESZ15 | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: Performing continuous futures contract back adjustment calculations. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: ESH5-CME Open price on 2015-03-12 is 2042. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: ESM5-CME Open price on 2015-03-12 is 2034.75. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: ESH5-CME price difference to ESM5-CME is -7.25. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: ESM5-CME Open price on 2015-06-11 is 2106. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: ESU5-CME Open price on 2015-06-11 is 2098.5. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: ESM5-CME price difference to ESU5-CME is -7.5. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: ESU5-CME Open price on 2015-09-10 is 1943.75. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: ESZ5-CME Open price on 2015-09-10 is 1934.75. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: ESU5-CME price difference to ESZ5-CME is -9. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: Back adjust amount for symbol ESH5-CME is -23.75. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: Back adjust amount for symbol ESM5-CME is -16.5. | 2015-12-07 07:27:45 ESZ5-CME [CB] 10 Min #18: Back adjust amount for symbol ESU5-CME is -9. | 2015-12-07 07:27:45 Date rule based rollover from ESZ5-CME to next contract occurs at 2015-12-10. | 2015-12-07 07:27:45 Checking Intraday data file for symbol ESZ5-CME for the date range from 2015-09-10 to 0. | 2015-12-07 07:27:45 ESZ5-CME [C] 10 Min #3 | Symbols used for continuous contract chart: | 2015-12-07 07:27:45 ESZ15 | 2015-12-07 07:27:45 Date rule based rollover from ESZ2-CME to next contract occurs at 2012-12-13. | 2015-12-07 07:27:45 Date rule based rollover from ESH3-CME to next contract occurs at 2013-03-07. | 2015-12-07 07:27:45 Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2015-12-07 07:27:45 Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2015-12-07 07:27:45 Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2015-12-07 07:27:45 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2015-12-07 07:27:45 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-12-07 07:27:45 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-12-07 07:27:45 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-12-07 07:27:45 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-12-07 07:27:45 Date rule based rollover from ESM5-CME to next contract occurs at 2015-06-11. | 2015-12-07 07:27:45 Date rule based rollover from ESU5-CME to next contract occurs at 2015-09-10. | 2015-12-07 07:27:45 Date rule based rollover from ESZ5-CME to next contract occurs at 2015-12-10. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-06-11. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESU15 for the date range from 2015-06-11 to 2015-09-10. | 2015-12-07 07:27:45 Checking Daily data file for symbol ESZ5-CME for the date range from 2015-09-10 to 2015-12-07. | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESZ5-CME.dly. Date: 2015-09-10, Price: 1939.75. Date: 2015-12-07, Price: 2093.75 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESU15.dly. Date: 2015-06-11, Price: 2101.5. Date: 2015-09-09, Price: 1942.75 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESM15.dly. Date: 2015-03-12, Price: 2056.5. Date: 2015-06-10, Price: 2107 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESH15.dly. Date: 2014-12-11, Price: 2024. Date: 2015-03-11, Price: 2039.5 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESZ14.dly. Date: 2014-09-11, Price: 1989. Date: 2014-12-10, Price: 2026.5 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESU14.dly. Date: 2014-06-12, Price: 1923.25. Date: 2014-09-10, Price: 1995 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESM14.dly. Date: 2014-03-13, Price: 1839.75. Date: 2014-06-11, Price: 1944 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESH14.dly. Date: 2013-12-12, Price: 1768.5. Date: 2014-03-12, Price: 1867.75 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESZ13.dly. Date: 2013-09-12, Price: 1678.25. Date: 2013-12-11, Price: 1780.75 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESU13.dly. Date: 2013-06-13, Price: 1631. Date: 2013-09-11, Price: 1688.75 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESM13.dly. Date: 2013-03-07, Price: 1537.75. Date: 2013-06-12, Price: 1610 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESH13.dly. Date: 2012-12-13, Price: 1412. Date: 2013-03-06, Price: 1539 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Price data for daily data file ESZ12.dly. Date: 2012-09-13, Price: 1450.5. Date: 2012-12-12, Price: 1427.25 | 2015-12-07 07:27:45 ESZ5-CME [C] Daily #8 | Symbols used for continuous contract chart: | 2015-12-07 07:27:45 ESZ12 | 2015-12-07 07:27:45 ESH13 | 2015-12-07 07:27:45 ESM13 | 2015-12-07 07:27:45 ESU13 | 2015-12-07 07:27:45 ESZ13 | 2015-12-07 07:27:45 ESH14 | 2015-12-07 07:27:45 ESM14 | 2015-12-07 07:27:45 ESU14 | 2015-12-07 07:27:45 ESZ14 | 2015-12-07 07:27:45 ESH15 | 2015-12-07 07:27:45 ESM15 | 2015-12-07 07:27:45 ESU15 | 2015-12-07 07:27:45 ESZ5-CME | 2015-12-07 07:27:45 Date rule based rollover from TF FMZ0015!-NYBOT to next contract occurs at 2015-12-10. | 2015-12-07 07:27:45 Checking Intraday data file for symbol TF FMZ0015!-NYBOT for the date range from 2015-09-10 to 0. | 2015-12-07 07:27:45 TF FMZ0015!-NYBOT [C] 1 Min #14 | Symbols used for continuous contract chart: | 2015-12-07 07:27:45 RJZ15 | 2015-12-07 07:27:45 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-12-07 07:27:45 * Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-12-07 07:27:46 * SC Market Stats | Starting real-time market data updates for: TICK-NYSE. ID: 1 | 2015-12-07 07:27:49 SC Market Stats | Connecting to the server ds5.sierracharts.com. Port 443 | 2015-12-07 07:27:49 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2015-12-07 07:27:49 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-07 07:27:49 HD Request # 2 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-12-07 07:27:49 HD Request # 2 | Download start Date-Time: 2015-12-07 07:26:00.000 | 2015-12-07 07:27:49 HD Request # 2 | Using server: ds3.sierracharts.com port 10149 | 2015-12-07 07:27:49 Rithmic Trading | Starting real-time market data updates for: ESZ5-CME. ID: 2 | 2015-12-07 07:27:49 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-07 07:27:49 Socket (6) | Connected. | 2015-12-07 07:27:49 HD Request # 2 | Sending historical data logon request message. | 2015-12-07 07:27:49 Intraday data recording state for symbol ESZ5-CME is set to download 'Pending'. | 2015-12-07 07:27:49 SC Market Stats | Starting real-time market data updates for: NISS-NYSE. ID: 3 | 2015-12-07 07:27:49 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2015-12-07 07:27:49 Socket (5) | Connected. | 2015-12-07 07:27:49 SC Market Stats | Connected to server. | 2015-12-07 07:27:49 SC Market Stats | Sending logon request message. | 2015-12-07 07:27:49 SC Market Stats | Starting real-time market data updates for: NISS-SP. ID: 4 | 2015-12-07 07:27:49 Intraday data recording state for symbol NISS-SP is set to download 'Pending'. | 2015-12-07 07:27:49 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-12-07 07:27:49 * SC Market Stats | Starting real-time market data updates for: NISS-NQ. ID: 5 | 2015-12-07 07:27:49 Intraday data recording state for symbol NISS-NQ is set to download 'Pending'. | 2015-12-07 07:27:49 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-12-07 07:27:49 * Rithmic Trading | Server Alert: mrv error : 13. Result text: "permission denied" | 2015-12-07 07:27:49 HD Request # 3 | Downloading Historical Daily chart data for ESZ5-CME. Starting date: 2015-12-04. Service: rim | 2015-12-07 07:27:49 HD Request # 3 | Requesting historical Daily data for ESZ15 starting at 2015-12-03 | 2015-12-07 07:27:49 Rithmic Trading | Starting real-time market data updates for: TF FMZ0015!-NYBOT. ID: 6 | 2015-12-07 07:27:49 Intraday data recording state for symbol TF FMZ0015!-NYBOT is set to download 'Pending'. | 2015-12-07 07:27:49 Rithmic Trading | Starting real-time market data updates for: NQZ5-CME. ID: 7 | 2015-12-07 07:27:49 Intraday data recording state for symbol NQZ5-CME is set to download 'Pending'. | 2015-12-07 07:27:49 Requesting market depth updates for: ESZ5-CME if supported. | 2015-12-07 07:27:49 Rithmic Trading | Server Alert: mrv error : 13. Result text: "permission denied" | 2015-12-07 07:27:49 Rithmic Trading | Server Alert: get_order_book error : 13. Result text: "permission denied" | 2015-12-07 07:27:49 Rithmic Trading | Server Alert: mrv error : 13. Result text: "permission denied" | 2015-12-07 07:27:49 Rithmic Trading | Server Alert: mrv error : 13. Result text: "permission denied" | 2015-12-07 07:27:49 HD Request # 3 | Receiving historical Daily data for ESZ5-CME starting at 2015-12-03 | 2015-12-07 07:27:50 Writing historical Daily data for ESZ5-CME to the file ESZ5-CME.dly | 2015-12-07 07:27:50 HD Request # 3 | Received 3 records from 2015-12-03 00:00:00 to 2015-12-07 00:00:00 (5.0 days) and wrote 2 records for ESZ5-CME | 2015-12-07 07:27:50 HD Request # 3 | Daily download COMPLETE for ESZ5-CME. Completion time: 1s. Unique request ID: 6 | 2015-12-07 07:27:50 Removed historical data download ID 6 | 2015-12-07 07:27:50 Date rule based rollover from ESZ2-CME to next contract occurs at 2012-12-13. | 2015-12-07 07:27:50 Date rule based rollover from ESH3-CME to next contract occurs at 2013-03-07. | 2015-12-07 07:27:50 Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2015-12-07 07:27:50 Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2015-12-07 07:27:50 Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2015-12-07 07:27:50 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2015-12-07 07:27:50 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-12-07 07:27:50 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-12-07 07:27:50 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-12-07 07:27:50 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-12-07 07:27:50 Date rule based rollover from ESM5-CME to next contract occurs at 2015-06-11. | 2015-12-07 07:27:50 Date rule based rollover from ESU5-CME to next contract occurs at 2015-09-10. | 2015-12-07 07:27:50 Date rule based rollover from ESZ5-CME to next contract occurs at 2015-12-10. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-06-11. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESU15 for the date range from 2015-06-11 to 2015-09-10. | 2015-12-07 07:27:50 Checking Daily data file for symbol ESZ5-CME for the date range from 2015-09-10 to 2015-12-07. | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESZ5-CME.dly. Date: 2015-09-10, Price: 1939.75. Date: 2015-12-07, Price: 2093.25 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESU15.dly. Date: 2015-06-11, Price: 2101.5. Date: 2015-09-09, Price: 1942.75 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESM15.dly. Date: 2015-03-12, Price: 2056.5. Date: 2015-06-10, Price: 2107 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESH15.dly. Date: 2014-12-11, Price: 2024. Date: 2015-03-11, Price: 2039.5 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESZ14.dly. Date: 2014-09-11, Price: 1989. Date: 2014-12-10, Price: 2026.5 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESU14.dly. Date: 2014-06-12, Price: 1923.25. Date: 2014-09-10, Price: 1995 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESM14.dly. Date: 2014-03-13, Price: 1839.75. Date: 2014-06-11, Price: 1944 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESH14.dly. Date: 2013-12-12, Price: 1768.5. Date: 2014-03-12, Price: 1867.75 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESZ13.dly. Date: 2013-09-12, Price: 1678.25. Date: 2013-12-11, Price: 1780.75 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESU13.dly. Date: 2013-06-13, Price: 1631. Date: 2013-09-11, Price: 1688.75 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESM13.dly. Date: 2013-03-07, Price: 1537.75. Date: 2013-06-12, Price: 1610 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESH13.dly. Date: 2012-12-13, Price: 1412. Date: 2013-03-06, Price: 1539 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Price data for daily data file ESZ12.dly. Date: 2012-09-13, Price: 1450.5. Date: 2012-12-12, Price: 1427.25 | 2015-12-07 07:27:50 ESZ5-CME [C] Daily #8 | Symbols used for continuous contract chart: | 2015-12-07 07:27:50 ESZ12 | 2015-12-07 07:27:50 ESH13 | 2015-12-07 07:27:50 ESM13 | 2015-12-07 07:27:50 ESU13 | 2015-12-07 07:27:50 ESZ13 | 2015-12-07 07:27:50 ESH14 | 2015-12-07 07:27:50 ESM14 | 2015-12-07 07:27:50 ESU14 | 2015-12-07 07:27:50 ESZ14 | 2015-12-07 07:27:50 ESH15 | 2015-12-07 07:27:50 ESM15 | 2015-12-07 07:27:50 ESU15 | 2015-12-07 07:27:50 ESZ5-CME | 2015-12-07 07:27:50 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2015-12-07 07:26:00. Record interval: 60. Symbol: TICK-NYSE | 2015-12-07 07:27:50 HD Request # 2 | Decompressing data. | 2015-12-07 07:27:50 HD Request # 2 | Receiving Intraday data for TICK-NYSE starting at 2015-12-07 07:26:00 | 2015-12-07 07:27:50 HD Request # 2 | Timestamp of first Intraday data file record written: 2015-12-07 07:26:00 | 2015-12-07 07:27:50 Socket (6) | Shutdown and closed. | 2015-12-07 07:27:50 The network socket for historical data has been closed. | 2015-12-07 07:27:50 HD Request # 2 | Received 2 records from 2015-12-07 07:26:00 to 2015-12-07 07:27:00 (60.0 seconds) and wrote 2 records for TICK-NYSE | 2015-12-07 07:27:50 HD Request # 2 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 1 | 2015-12-07 07:27:50 Removed historical data download ID 1 | 2015-12-07 07:27:50 Real-time Intraday chart data file updates started for TICK-NYSE | 2015-12-07 07:27:50 HD Request # 4 | Downloading Intraday chart data for ESZ5-CME to the file ESZ5-CME.scid. Service: cme | 2015-12-07 07:27:50 HD Request # 4 | Download start Date-Time: 2015-12-07 07:15:02.000 | 2015-12-07 07:27:50 HD Request # 4 | Using server: scdf2.sierracharts.com port 10149 | 2015-12-07 07:27:50 SC Market Stats | Server Name: SC Realtime Server. | 2015-12-07 07:27:50 SC Market Stats | Server protocol version: 7. Client protocol version: 7 | 2015-12-07 07:27:50 SC Market Stats | Successfully connected. | 2015-12-07 07:27:50 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-12-07 07:27:50 SC Market Stats | Restarting real-time data updates for symbol: NISS-NQ | 2015-12-07 07:27:50 SC Market Stats | Restarting real-time data updates for symbol: NISS-NYSE | 2015-12-07 07:27:50 SC Market Stats | Restarting real-time data updates for symbol: NISS-SP | 2015-12-07 07:27:50 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2015-12-07 07:27:50 SC Market Stats | Restarting real-time data updates for symbol: TICK-NYSE | 2015-12-07 07:27:50 Socket (8) | Connected. | 2015-12-07 07:27:50 HD Request # 4 | Sending historical data logon request message. | 2015-12-07 07:27:50 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-12-07 07:15:02. Record interval: 60. Symbol: ESZ15 | 2015-12-07 07:27:50 HD Request # 4 | Decompressing data. | 2015-12-07 07:27:50 HD Request # 4 | Receiving Intraday data for ESZ5-CME starting at 2015-12-07 07:15:02 | 2015-12-07 07:27:50 HD Request # 4 | Timestamp of first Intraday data file record written: 2015-12-07 07:15:02 | 2015-12-07 07:27:50 Socket (8) | Shutdown and closed. | 2015-12-07 07:27:50 The network socket for historical data has been closed. | 2015-12-07 07:27:50 HD Request # 4 | Received 3 records from 2015-12-07 07:15:02 to 2015-12-07 07:17:02 (2.0 minutes) and wrote 3 records for ESZ5-CME | 2015-12-07 07:27:50 HD Request # 4 | Intraday download COMPLETE for ESZ5-CME. Completion time: 0s. Unique request ID: 2 | 2015-12-07 07:27:50 Removed historical data download ID 2 | 2015-12-07 07:27:50 Real-time Intraday chart data file updates started for ESZ5-CME | 2015-12-07 07:27:50 Intraday data recording state for symbol ESZ5-CME is set to download 'Pending'. | 2015-12-07 07:27:50 HD Request # 5 | Downloading Intraday chart data for ESZ5-CME to the file ESZ5-CME.scid. Service: rim | 2015-12-07 07:27:50 HD Request # 5 | Download start Date-Time: 2015-12-07 07:17:02.000 | 2015-12-07 07:27:50 HD Request # 5 | Sending historical data request. Start Date-Time: 2015-12-07 07:17:02. Record interval: 60. Symbol: ESZ5-CME | 2015-12-07 07:27:50 HD Request # 6 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2015-12-07 07:27:50 HD Request # 6 | Download start Date-Time: 2015-12-07 07:26:00.000 | 2015-12-07 07:27:50 Rithmic Trading | Requesting historical Minute data. | 2015-12-07 07:27:50 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2015-12-07 07:27:50 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-07 07:27:50 Chart #10 has tagged chart #17 for full recalculation. Chartbook: TaylorTransformational.cht | 2015-12-07 07:27:50 Chart #4 has tagged chart #9 for full recalculation. Chartbook: TaylorTransformational.cht | 2015-12-07 07:27:50 Chart #9 is performing a full recalculation because it has been tagged. Chartbook: TaylorTransformational.cht | 2015-12-07 07:27:50 Socket (9) | Connected. | 2015-12-07 07:27:50 HD Request # 6 | Sending historical data logon request message. | 2015-12-07 07:27:50 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-12-07 07:26:00. Record interval: 60. Symbol: NISS-NYSE | 2015-12-07 07:27:51 HD Request # 6 | Decompressing data. | 2015-12-07 07:27:51 HD Request # 6 | Receiving Intraday data for NISS-NYSE starting at 2015-12-07 07:26:00 | 2015-12-07 07:27:51 HD Request # 6 | Timestamp of first Intraday data file record written: 2015-12-07 07:26:00 | 2015-12-07 07:27:51 Socket (9) | Shutdown and closed. | 2015-12-07 07:27:51 The network socket for historical data has been closed. | 2015-12-07 07:27:51 HD Request # 5 | Error downloading historical Intraday data for ESZ5-CME. Error downloading historical Minute data. Error: permission denied | 2015-12-07 07:27:54 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ5-CME | 2015-12-07 07:27:54 HD Request # 5 | Intraday download COMPLETE for ESZ5-CME. Completion time: 4s. Unique request ID: 10 | 2015-12-07 07:27:54 Removed historical data download ID 10 | 2015-12-07 07:27:54 Real-time Intraday chart data file updates started for ESZ5-CME | 2015-12-07 07:27:54 HD Request # 6 | Received 2 records from 2015-12-07 07:26:00 to 2015-12-07 07:27:00 (60.0 seconds) and wrote 2 records for NISS-NYSE | 2015-12-07 07:27:54 HD Request # 6 | Intraday download COMPLETE for NISS-NYSE. Completion time: 4s. Unique request ID: 3 | 2015-12-07 07:27:54 Removed historical data download ID 3 | 2015-12-07 07:27:54 Real-time Intraday chart data file updates started for NISS-NYSE | 2015-12-07 07:27:54 HD Request # 7 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2015-12-07 07:27:54 HD Request # 7 | Download start Date-Time: 2015-12-07 07:26:00.000 | 2015-12-07 07:27:54 HD Request # 7 | Using server: ds5.sierracharts.com port 10149 | 2015-12-07 07:27:54 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-07 07:27:54 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-12-07 07:27:54 * Chart #17 is performing a full recalculation because it has been tagged. Chartbook: TaylorTransformational.cht | 2015-12-07 07:27:54 Socket (10) | Connected. | 2015-12-07 07:27:54 HD Request # 7 | Sending historical data logon request message. | 2015-12-07 07:27:54 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-12-07 07:27:54 * Chart #4 has tagged chart #9 for full recalculation. Chartbook: TaylorTransformational.cht | 2015-12-07 07:27:54 Chart #7 has tagged chart #17 for full recalculation. Chartbook: TaylorTransformational.cht | 2015-12-07 07:27:54 Chart #9 is performing a full recalculation because it has been tagged. Chartbook: TaylorTransformational.cht | 2015-12-07 07:27:54 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-12-07 07:26:00. Record interval: 60. Symbol: NISS-SP | 2015-12-07 07:27:54 HD Request # 7 | Decompressing data. | 2015-12-07 07:27:54 HD Request # 7 | Receiving Intraday data for NISS-SP starting at 2015-12-07 07:26:00 | 2015-12-07 07:27:54 HD Request # 7 | Timestamp of first Intraday data file record written: 2015-12-07 07:26:00 | 2015-12-07 07:27:54 Socket (10) | Shutdown and closed. | 2015-12-07 07:27:54 The network socket for historical data has been closed. | 2015-12-07 07:27:54 HD Request # 7 | Received 2 records from 2015-12-07 07:26:00 to 2015-12-07 07:27:00 (60.0 seconds) and wrote 2 records for NISS-SP | 2015-12-07 07:27:57 HD Request # 7 | Intraday download COMPLETE for NISS-SP. Completion time: 3s. Unique request ID: 4 | 2015-12-07 07:27:57 Removed historical data download ID 4 | 2015-12-07 07:27:57 Real-time Intraday chart data file updates started for NISS-SP | 2015-12-07 07:27:57 HD Request # 8 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc | 2015-12-07 07:27:57 HD Request # 8 | Download start Date-Time: 2015-12-07 07:26:00.000 | 2015-12-07 07:27:57 HD Request # 8 | Using server: ds3.sierracharts.com port 10149 | 2015-12-07 07:27:57 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-07 07:27:57 Socket (11) | Connected. | 2015-12-07 07:27:57 HD Request # 8 | Sending historical data logon request message. | 2015-12-07 07:27:57 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: TaylorTransformational.cht | 2015-12-07 07:27:57 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-12-07 07:26:00. Record interval: 60. Symbol: NISS-NQ | 2015-12-07 07:27:57 HD Request # 8 | Decompressing data. | 2015-12-07 07:27:57 HD Request # 8 | Receiving Intraday data for NISS-NQ starting at 2015-12-07 07:26:00 | 2015-12-07 07:27:57 HD Request # 8 | Timestamp of first Intraday data file record written: 2015-12-07 07:26:00 | 2015-12-07 07:27:57 Socket (11) | Shutdown and closed. | 2015-12-07 07:27:57 The network socket for historical data has been closed. | 2015-12-07 07:27:57 HD Request # 8 | Received 2 records from 2015-12-07 07:26:00 to 2015-12-07 07:27:00 (60.0 seconds) and wrote 2 records for NISS-NQ | 2015-12-07 07:27:57 HD Request # 8 | Intraday download COMPLETE for NISS-NQ. Completion time: 0s. Unique request ID: 5 | 2015-12-07 07:27:57 Removed historical data download ID 5 | 2015-12-07 07:27:57 Real-time Intraday chart data file updates started for NISS-NQ | 2015-12-07 07:27:57 HD Request # 9 | Downloading Intraday chart data for TF FMZ0015!-NYBOT to the file TF FMZ0015!-NYBOT.scid. Service: ice.us | 2015-12-07 07:27:57 HD Request # 9 | Download start Date-Time: 2015-12-07 07:10:23.000 | 2015-12-07 07:27:57 HD Request # 9 | Using server: scdf1.sierracharts.com port 10149 | 2015-12-07 07:27:57 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-12-07 07:27:57 Socket (12) | Connected. | 2015-12-07 07:27:58 HD Request # 9 | Sending historical data logon request message. | 2015-12-07 07:27:58 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2015-12-07 07:10:23. Record interval: 60. Symbol: RJZ15 | 2015-12-07 07:27:58 HD Request # 9 | Decompressing data. | 2015-12-07 07:27:58 HD Request # 9 | Receiving Intraday data for TF FMZ0015!-NYBOT starting at 2015-12-07 07:10:23 | 2015-12-07 07:27:58 HD Request # 9 | Timestamp of first Intraday data file record written: 2015-12-07 07:10:23 | 2015-12-07 07:27:58 Socket (12) | Shutdown and closed. | 2015-12-07 07:27:58 The network socket for historical data has been closed. | 2015-12-07 07:27:58 HD Request # 9 | Received 3 records from 2015-12-07 07:10:23 to 2015-12-07 07:12:04 (101.0 seconds) and wrote 3 records for TF FMZ0015!-NYBOT | 2015-12-07 07:27:58 HD Request # 9 | Intraday download COMPLETE for TF FMZ0015!-NYBOT. Completion time: 1s. Unique request ID: 7 | 2015-12-07 07:27:58 Removed historical data download ID 7 | 2015-12-07 07:27:58 Real-time Intraday chart data file updates started for TF FMZ0015!-NYBOT | 2015-12-07 07:27:58 Intraday data recording state for symbol TF FMZ0015!-NYBOT is set to download 'Pending'. | 2015-12-07 07:27:58 HD Request # 10 | Downloading Intraday chart data for TF FMZ0015!-NYBOT to the file TF FMZ0015!-NYBOT.scid. Service: rim | 2015-12-07 07:27:58 HD Request # 10 | Download start Date-Time: 2015-12-07 07:12:04.000 | 2015-12-07 07:27:58 HD Request # 10 | Sending historical data request. Start Date-Time: 2015-12-07 07:12:04. Record interval: 60. Symbol: TF FMZ0015!-NYBOT | 2015-12-07 07:27:58 HD Request # 11 | Downloading Intraday chart data for NQZ5-CME to the file NQZ5-CME.scid. Service: cme | 2015-12-07 07:27:58 HD Request # 11 | Download start Date-Time: 2015-12-07 07:15:10.000 | 2015-12-07 07:27:58 HD Request # 11 | Using server: scdf2.sierracharts.com port 10149 | 2015-12-07 07:27:58 Rithmic Trading | Requesting historical Minute data. | 2015-12-07 07:27:58 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-12-07 07:27:58 HD Request # 10 | Error downloading historical Intraday data for TF FMZ0015!-NYBOT. Error downloading historical Minute data. Error: permission denied | 2015-12-07 07:27:58 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0015!-NYBOT | 2015-12-07 07:27:58 HD Request # 10 | Intraday download COMPLETE for TF FMZ0015!-NYBOT. Completion time: 0s. Unique request ID: 11 | 2015-12-07 07:27:58 Removed historical data download ID 11 | 2015-12-07 07:27:58 Real-time Intraday chart data file updates started for TF FMZ0015!-NYBOT | 2015-12-07 07:27:58 Socket (13) | Connected. | 2015-12-07 07:27:58 HD Request # 11 | Sending historical data logon request message. | 2015-12-07 07:27:58 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2015-12-07 07:15:10. Record interval: 60. Symbol: NQZ15 | 2015-12-07 07:27:58 HD Request # 11 | Decompressing data. | 2015-12-07 07:27:58 HD Request # 11 | Receiving Intraday data for NQZ5-CME starting at 2015-12-07 07:15:10 | 2015-12-07 07:27:58 HD Request # 11 | Timestamp of first Intraday data file record written: 2015-12-07 07:15:10 | 2015-12-07 07:27:58 Socket (13) | Shutdown and closed. | 2015-12-07 07:27:58 The network socket for historical data has been closed. | 2015-12-07 07:27:58 HD Request # 11 | Received 3 records from 2015-12-07 07:15:10 to 2015-12-07 07:17:01 (111.0 seconds) and wrote 3 records for NQZ5-CME | 2015-12-07 07:27:58 HD Request # 11 | Intraday download COMPLETE for NQZ5-CME. Completion time: 0s. Unique request ID: 8 | 2015-12-07 07:27:58 Removed historical data download ID 8 | 2015-12-07 07:27:58 Real-time Intraday chart data file updates started for NQZ5-CME | 2015-12-07 07:27:58 Intraday data recording state for symbol NQZ5-CME is set to download 'Pending'. | 2015-12-07 07:27:58 HD Request # 12 | Downloading Intraday chart data for NQZ5-CME to the file NQZ5-CME.scid. Service: rim | 2015-12-07 07:27:58 HD Request # 12 | Download start Date-Time: 2015-12-07 07:17:01.000 | 2015-12-07 07:27:58 HD Request # 12 | Sending historical data request. Start Date-Time: 2015-12-07 07:17:01. Record interval: 60. Symbol: NQZ5-CME | 2015-12-07 07:27:58 HD Request # 13 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-12-07 07:27:58 HD Request # 13 | Download start Date-Time: 2015-12-07 07:27:00.000 | 2015-12-07 07:27:58 HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2015-12-07 07:27:58 Rithmic Trading | Requesting historical Minute data. | 2015-12-07 07:27:58 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-07 07:27:58 HD Request # 12 | Error downloading historical Intraday data for NQZ5-CME. Error downloading historical Minute data. Error: permission denied | 2015-12-07 07:27:58 HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQZ5-CME | 2015-12-07 07:27:58 HD Request # 12 | Intraday download COMPLETE for NQZ5-CME. Completion time: 0s. Unique request ID: 12 | 2015-12-07 07:27:58 Removed historical data download ID 12 | 2015-12-07 07:27:58 Real-time Intraday chart data file updates started for NQZ5-CME | 2015-12-07 07:27:58 Socket (14) | Connected. | 2015-12-07 07:27:58 HD Request # 13 | Sending historical data logon request message. | 2015-12-07 07:27:58 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2015-12-07 07:27:00. Record interval: 60. Symbol: TICK-NYSE | 2015-12-07 07:27:58 HD Request # 13 | Decompressing data. | 2015-12-07 07:27:58 HD Request # 13 | Receiving Intraday data for TICK-NYSE starting at 2015-12-07 07:27:00 | 2015-12-07 07:27:58 HD Request # 13 | Timestamp of first Intraday data file record written: 2015-12-07 07:27:00 | 2015-12-07 07:27:58 Socket (14) | Shutdown and closed. | 2015-12-07 07:27:58 The network socket for historical data has been closed. | 2015-12-07 07:27:58 HD Request # 13 | Received 1 record from 2015-12-07 07:27:00 to 2015-12-07 07:27:00 (0.0 seconds) and wrote 1 record for TICK-NYSE | 2015-12-07 07:27:58 HD Request # 13 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 9 | 2015-12-07 07:27:58 Removed historical data download ID 9 | 2015-12-07 07:27:58 Real-time Intraday chart data file updates started for TICK-NYSE | 2015-12-07 07:27:58 Chart #10 has tagged chart #17 for full recalculation. Chartbook: TaylorTransformational.cht | 2015-12-07 07:27:59 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: TaylorTransformational.cht | 2015-12-07 07:27:59 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-12-07 07:28:30 Date rule based rollover from ESM5-CME to next contract occurs at 2015-06-11. | 2015-12-07 07:28:30 Date rule based rollover from ESU5-CME to next contract occurs at 2015-09-10. | 2015-12-07 07:28:30 Date rule based rollover from ESZ5-CME to next contract occurs at 2015-12-10. | 2015-12-07 07:28:30 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-12-07 07:28:30 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-12-07 07:28:30 Checking Intraday data file for symbol ESM5-CME for the date range from 2015-03-12 to 2015-06-11. | 2015-12-07 07:28:30 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-06-11. | 2015-12-07 07:28:30 Checking Intraday data file for symbol ESU5-CME for the date range from 2015-06-11 to 2015-09-10. | 2015-12-07 07:28:30 Checking Daily data file for symbol ESU15 for the date range from 2015-06-11 to 2015-09-10. | 2015-12-07 07:28:30 Checking Intraday data file for symbol ESZ5-CME for the date range from 2015-09-10 to 0. | 2015-12-07 07:28:30 Checking Daily data file for symbol ESZ15 for the date range from 2015-09-10 to 2015-12-07. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9 | Price data for daily data file ESZ15.dly. Date: 2015-09-10, Price: 1939.75. Date: 2015-12-07, Price: 2091.5 | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9 | Price data for daily data file ESU15.dly. Date: 2015-06-11, Price: 2101.5. Date: 2015-09-09, Price: 1942.75 | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9 | Price data for daily data file ESM15.dly. Date: 2015-03-12, Price: 2056.5. Date: 2015-06-10, Price: 2107 | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9 | Price data for daily data file ESH15.dly. Date: 2014-12-11, Price: 2024. Date: 2015-03-11, Price: 2039.5 | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-12-07 07:28:30 ESH15 | 2015-12-07 07:28:30 ESM15 | 2015-12-07 07:28:30 ESU15 | 2015-12-07 07:28:30 ESZ15 | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: ESH5-CME Open price on 2015-03-12 is 2042. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: ESM5-CME Open price on 2015-03-12 is 2034.75. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: ESH5-CME price difference to ESM5-CME is -7.25. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: ESM5-CME Open price on 2015-06-11 is 2106. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: ESU5-CME Open price on 2015-06-11 is 2098.5. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: ESM5-CME price difference to ESU5-CME is -7.5. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: ESU5-CME Open price on 2015-09-10 is 1943.75. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: ESZ5-CME Open price on 2015-09-10 is 1934.75. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: ESU5-CME price difference to ESZ5-CME is -9. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: Back adjust amount for symbol ESH5-CME is -23.75. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: Back adjust amount for symbol ESM5-CME is -16.5. | 2015-12-07 07:28:30 ESZ5-CME [CB] 5 Min #9: Back adjust amount for symbol ESU5-CME is -9. | 2015-12-07 07:28:30 A request for the latest software update has been made. | 2015-12-07 07:32:10 * The update is being downloaded in the background. When it is complete, you will be prompted. | 2015-12-07 07:32:10 * Download for software update has been redirected. Request ID: 1 -> 2 | 2015-12-07 07:32:10 File has been written to: C:\SierraChart\SierraChartSetup.exe. File Size: 22319988 bytes. | 2015-12-07 07:32:30 I attach a screenshot image showing the current version as 1307, after supposedly effecting the current download. |
Capture.PNG / V - Attached On 2015-12-07 12:37:57 UTC - Size: 8.31 KB - 279 views Attachment Deleted. |
[2015-12-07 17:35:18] |
Newer versions of Sierra Chart do not include support for Old Spreadsheets and this is the reason for the problem. Refer to this page here: Differences Between New Spreadsheets and Old Spreadsheets So to get the very latest Sierra Chart version you need to use the Download commands for New Spreadsheets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-07 17:37:02
