Date/Time: Wed, 25 Dec 2024 02:31:29 +0000
Time and Sales window oddities
View Count: 1122
[2015-11-11 21:43:37]
Japhro - Posts: 120
A couple of things I have noted about the time and sales window on SC :
1. does not have the ability to keep 'window always visible' or 'always on top'
2. closes when you switch chartbooks, so you must duplicate this for each chartbook that you intend to use if you want it viewable at all times
3. closes when you minimise the main chart/workspace window, making it unviewable
4. No way to save settings as a default, so that you can easily replicate custom colours and settings on this, so each one has to be manually tweaked
I would simply like to have a single T&S open at all times for one instrument, that is viewable regardless of the chartbook that is open, and preferably be able to save the settings as a default. I can't even copy this to another chartbook as there are no provisions in the menu for this such as 'duplicate chart'.
Any thoughts on additions for this to make it more user friendly? Thanks
[2015-11-12 04:48:36]
Refer to these two sections here:
http://www.sierrachart.com/index.php?page=doc/doc_TimeandSalesWindow.html#SameTimeSalesWindowVisibleAcrossChartbooks
http://www.sierrachart.com/index.php?page=doc/doc_TimeandSalesWindow.html#DefaultSettings
[2015-11-12 13:16:46]
Japhro - Posts: 120
Fair enough, but that also requires that one chart related to the T&S must be visible at all times, if not, no time and sales window. Its a strange function, maybe T&S can be chart independent at some point?
[2015-11-12 13:21:47]
Japhro - Posts: 120
Actually, your description is incorrect, 'window always visible' will not keep the T&S open at all times even though that chart is still visible. If I switch chartbooks, and the chart that in question is on another screen, and still visible, the T&S disappears. It requires that 'Always On Top be checked'. to get T&S visible at all times in other words, requires that at least one chart is Always on top, which isn't convenient in terms of using screen space.
Date Time Of Last Edit: 2015-11-12 13:22:23
[2015-11-12 18:58:22]
This does not make sense. We understand the chart is detached from the main Sierra Chart window? If so, that will not matter, the Time and Sales window for it is still visible so long as the chart is not behind some other windows on the system.
As we read and understand this, this just does not make any sense. You will still see the Time and Sales window. Maybe you can attach a screenshot showing what you are seeing so we can understand this better.
Date Time Of Last Edit: 2015-11-12 19:00:13
