Date/Time: Wed, 25 Dec 2024 02:03:41 +0000
Countdown timer
View Count: 943
[2015-11-11 21:26:23]
User307319 - Posts: 41
Dear Sierra, I am using 30 seconds and 10 seconds timeframes.Working with E-mini. In both charts the seconds continue to jump - it may freeze for up to 6 seconds, and then show directly new value. Please, advise how to fix this, so I can properly timing my entries and exits. Thank you, Irina
[2015-11-12 04:16:18]
What is the Global Settings >> Data/Trade Service Settings >> Service set to?
What is the exact symbol of the chart?
Also refer to help topic 4.10 here:
http://www.sierrachart.com/index.php?page=doc/helpdetails4.html#h4.10
What you are describing is not necessarily unusual. You cannot expect a trade every second.
[2015-11-12 13:58:21]
You mean intraday data? It was ticks and i switched now in second, maybe this was a problem.
The symbol is ES201512, trades occuring every milleseconds, correct?
Will install NTP after market close
[2015-11-12 15:10:55]
Thank you - excellent so far, till now no any delays.
[2015-11-12 17:36:05]
No, trades do not occur every millisecond for the ES futures. Not at all.
[2015-11-12 21:10:25]
O, thank you. I thought it is. In any way the counterdown gave some minor slippage but not as before, I undesrtand now it is connected with trading activity. Thank you, have a nice evening.
