Date/Time: Wed, 25 Dec 2024 02:35:19 +0000
How to sincronize numbers of position on chart and Dom
View Count: 974
[2015-11-11 21:17:01]
User307319 - Posts: 41
Yestarday I had in simulator account the position on the chart shows +1@2070.67 while the position in the DOM shows 1@2071.75. How can we get these 2 numbers to sync with one another? Thank you, Irina
imageSierra1011152numbers.jpg / V - Attached On 2015-11-11 21:16:40 UTC - Size: 200.71 KB - 323 views
[2015-11-12 04:22:24]
When you want to post an image of a chart, use only this method here:
That image is not useful because it contains a high amount of loss and too much information. We will not struggle to look at a poor quality image.
The reason you would see a difference with Trade Position data when Trade Simulation Mode is on, between charts has to do with a difference with the number of order fills loaded in the charts.
We have made some changes to eliminate this kind of difference in newer versions. Update Sierra Chart following the instructions here:
http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
The only thing you would have to check is to make sure there is no Date-Time set in Chart >> Chart Settings >> Advanced Settings >> Order Fills Start Date-Time.
[2015-11-12 14:03:48]
The screen image was not possible to take once it was not more availble. Hope with the new version downloaded today it is fixed. There is no Data-Time set.
[2015-11-12 15:23:22]
It is repeating again - http://www.sierrachart.com/image.php?l=1447341648322.png
[2015-11-12 15:24:07]
You noticed on the cahrt position shown at 2055 and on the DOm at 2056.
[2015-11-12 19:20:06]
You are referring to a difference with the Position Average price between the Trade Window and the Position Line. This is because you have enabled this option:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#FlatToFlatAveragePriceForPosition
[2015-11-12 21:18:02]
Thank you very much, i did not choose it, probably it was prebuild. How I can sincronize thoose two numbers, please, and see real average price of filled position?
[2015-11-13 09:04:23]
You need to uncheck that option. It is in Global Settings >> Chart Trade Settings.
