Date/Time: Tue, 24 Dec 2024 18:10:20 +0000
Win10&sierra
View Count: 1204
[2015-11-11 19:35:56]
User793415 - Posts: 3
Hello!
Has got the problem with programm.I downloaded and installation wont start under windows10.I read here it should work fine under windows 10.Any suggest how to fix this,pls?
thank you Michal
[2015-11-12 04:43:17]
Do you see any error message when you start Sierra Chart? If so, what is the message?
Make sure you install the Microsoft Visual C++ redistributable package :
http://www.microsoft.com/en-us/download/details.aspx?id=8328
