Date/Time: Tue, 24 Dec 2024 18:18:54 +0000
Template for studies
View Count: 908
[2015-11-11 17:24:35] |
User515532 - Posts: 19 |
Hi, I am new to Seirra Chart and would like to know is there any way to save configured studies as standard template or as saved file so that if there is re-installation, can restore easily. Also, currently I am using version 1227 and found that it does not have Delta Divergence and Delta Ladder. Is there any way to install these two studies in version 1227? Regards, Clement |
[2015-11-11 18:26:32] |
Refer to the Study Collections page here: https://www.sierrachart.com/index.php?page=doc/doc_StudyCollections.html Update Sierra Chart by following these instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate You must update to get these studies. What is the reason you are using 1227 and do not want to update? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
