Date/Time: Tue, 24 Dec 2024 17:43:19 +0000
spreadsheet help
View Count: 782
[2015-11-11 13:27:59]
User20450 - Posts: 330
have a quick question if someone can help - i was inputting a code into entry box on spread sheet =id1.sg1>id3.sg1 and im getting a #value instead of a true or false , what does that mean ?
[2015-11-11 14:03:47]
Sawtooth - Posts: 4142
The syntax for Simple Alerts and spreadsheets is not the same. Spreadsheets require a row reference. Try this:
=id1.sg1@3>id3.sg1@3
[2015-11-11 14:11:48]
oh sweet thanks man , im learning the syntax , so building basic systems to learn it
[2015-11-11 17:57:00]
Refer to the documentation for this here:
https://www.sierrachart.com/index.php?page=doc/doc_Spreadsheets.html#VALUEError
