Date/Time: Sun, 04 Oct 2026 15:33:05 +0000
StopAllInternalOrderID
View Count: 1520
[2015-11-11 08:59:35]
User99735 - Posts: 234
In a strategy I am opening multiple orders with attached targets and a single stop. The internalId of the stop order is fetched using NewOrder.StopAllInternalOrderID.
a) Appears the internalId returned by this function is not good for using with function sc.GetOrderByOrderID() to get the Stop Order
b) Am not able to use sc.GetNearestStopOrder() as there are multiple orders along with attached stops present.
c) So should I use the following sc.GetOrderByIndex() to go through all the orders and find the attached stops, or is there a better way available.
Regards
Vivek
[2015-11-11 09:37:10]
ACSIL does return all of the Internal Order IDs for all of the stop orders. Refer to the documentation for this here:
https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#StopInternalOrderID
[2015-11-11 09:39:55]
Ok, so what is the difference between StopAllInternalOrderID and StopAllInternalOrderID_2. What is the difference between the two, there should be only one StopAll ID, isnt it, and which one returns the correct ID.
Regards
Vivek
[2015-11-11 09:43:25]
Really it would be best after submitting the order that you look at all of the Internal Order IDs using a debugger, then you can clearly see what is set.
This is the relevant paragraph:
In the case when you are using StopAllOffset , then for every Target# being used, the corresponding Stop#InternalOrderID will be set, since there will be multiple Stop orders, one for each Target#.
If there are 2 Stop orders created, then these will have the internal order IDs for them:
Stop1InternalOrderID
Stop2InternalOrderID
Date Time Of Last Edit: 2015-11-11 09:44:09
[2015-11-11 10:46:59]
Ok so even with StopAllOffset, separate stops are created for each target, so StopAllInternalOrderID maybe pointing to the first or the last stop order?
[2015-11-11 18:10:11]
It will contain the Internal Order ID for the first order. The documentation does state this clearly.
Date Time Of Last Edit: 2015-11-11 18:24:25
