Date/Time: Tue, 24 Dec 2024 18:38:16 +0000
Wrong PnL Colors in DOM in Version 1324
View Count: 821
[2015-11-11 07:43:16] |
nicktrader - Posts: 721 |
I am running the new version 1324. The colors of the PnL in the DOM changed.
PnLColor.png / V - Attached On 2015-11-11 07:42:25 UTC - Size: 22.03 KB - 308 views |
[2015-11-11 08:53:28] |
The coloring of the Profit/Loss Column on the Chart/Trade DOM has been changed. By default, the numbers use the coloring of the values scale. When a Position has a profit, only those profit values are colored from the entry price to the level of the current price. When a Position has a loss, only those loss values are colored from the entry price to the level of the current price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-11 09:06:49] |
From my point of view the previous version was much better. Is there a way to use the previous coloring setting?
[2015-11-11 09:39:01] |
Yes of course. This is what we were afraid of. We are just afraid of putting too many different options in. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
