Date/Time: Wed, 25 Dec 2024 01:37:28 +0000
User Question
View Count: 1046
[2015-11-11 03:08:31] |
Sierra Chart - Max - Posts: 5758 |
P.S. Is there also a way to do a chart overlay so he can have 2 charts in one window, but not so that the charts are on top of one another; instead, he wants a vertical split screen where one chart would take up the left side of the window and the second chart would take up the right half of the monitor. We did an overlay, but it only gave us a horizontal option, not 2 vertical charts next to each other. Does any option like this exist in SierraChart? Sierra Chart Support |
[2015-11-13 03:37:26] |
Open 2 charts as explained here: http://www.sierrachart.com/index.php?page=doc/doc_GettingStarted.php#OpenChart And then tile them using this command: http://www.sierrachart.com/index.php?page=doc/doc_WindowMenu.html#TileVertically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
