Date/Time: Tue, 24 Dec 2024 18:00:08 +0000
Can I use a hotkey or a button to switch between chart timeframes on a detached chart?
View Count: 812
[2015-11-11 01:28:49] |
trader1 - Posts: 128 |
Hi, Can I use a hotkey or a button to switch between chart timeframes on a detached chart? Thanks. |
[2015-11-11 03:37:43] |
Yes you can and this is fully documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChangingPeriodOfBars.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
