Date/Time: Tue, 24 Dec 2024 17:54:32 +0000
Tick chart
View Count: 803
[2015-11-10 21:47:02]
Jerry J Sears - Posts: 27
Is there a way to add a tick chart to the tool bar for bar period like the 1 min button?
[2015-11-10 23:41:33]
Gabe - Posts: 3
Yes
http://www.sierrachart.com/index.php?page=doc/doc_ChangingPeriodOfBars.php
Short version, global settings, customized tool bar, select which bar, open up chart bar period, select one of the custom periods, move it into your bar, highlight it and click set period.
[2015-11-11 05:36:26]
Yes, and this is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar
