Date/Time: Wed, 24 Apr 2024 10:33:54 +0000
Copy Chart Drawings From Chart # to Trade Dom
View Count: 1286
[2013-06-19 20:33:17] |
User30668 - Posts: 108 |
Hello, I am trying to use the "Copy Chart Drawings From Chart #'s" function with the Trade Dom, in order to have some horizontal lines drawn on a chart replicated in the Trade Dom. I couldn't get it to work through "Chart Settings / Advanced Settings / Copy Chart Drawings From Chart #'s". It simply doesn't show any drawings from the designated chart. Is this function not possible to set with the Trading Dom or am I missing anything? Thanks in advance. Date Time Of Last Edit: 2013-06-20 09:51:29
[2013-06-20 15:05:09] |
I am sorry to insist on this but I didn't have any reply and I would really like to know it: Is it possible to have horizontal lines drawn in a chart replicated (plotted) in the Trade Dom using the option “Copy Chart Drawings From Chart #’s”? Thanks. Date Time Of Last Edit: 2013-06-20 15:07:28
[2013-06-20 17:14:02] |
This is not currently supported, but we will see about allowing this.
[2019-12-06 09:29:27] |
BenjFlame - Posts: 305 |
That would be a great feature to have +1
[2019-12-07 05:48:25] |
This is already supported, but it may not work properly because a Trading DOM does not have chart bars. But you can try copying Horizontal lines.
