Date/Time: Tue, 24 Dec 2024 18:16:35 +0000
Filling the Area Between Two Study Subgraphs, using Fill Bottom and Fill Top on two subgrh
View Count: 755
[2015-11-10 11:11:28] |
KhaosTrader - Posts: 128 |
hi, I have a study that uses two subgraph pairs, which need fills, I tried using two fill bottom and fill top pairs, with no luck, If i use different type of fill pairs that works, but the look is not consistent. How do I use the same fill type for two different pairs on the same study please. |
[2015-11-10 11:29:18] |
Attach a screenshot of the Study Settings >> Subgraphs tab so that we can see the configuration of the Different Subgraph Draw Styles.
[2015-11-10 17:31:57] |
I had a mistake in my code, which i discovered, apologies... I have it working now, thank you.
