Date/Time: Tue, 24 Dec 2024 18:20:22 +0000
Chart Order Fill Box location
View Count: 1054
[2015-11-09 20:17:23] |
User842703 - Posts: 55 |
Sometimes these boxes go off the chart when there are wide price swings within the current frame. Is there a way to scale them within the chart window so they always remain visible?
[2015-11-11 05:28:31] |
What you need to do is use the Interactive Scale Range feature to expand the range of prices so you can see these boxes. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#InteractiveScaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
