Date/Time: Tue, 24 Dec 2024 17:56:09 +0000
Automatic Pair trading...
View Count: 1039
[2015-11-09 14:28:40] |
User368248 - Posts: 46 |
Hello. I am new on SC, thanks in advance for your help and direction on this issue. I have 2 instances running SC with 2 trading providers, fxcm and rithmic I can see on instance1 both symbols: symbol1/fxcm and symbol2/rithmic I already apply RATIO study, I can see the diference/ratio of such symbols 1.- How can I monitor in real time ( no chart only ) the gap/ratio? 2.- How can I send automatic sell symbol1/fxcm and buy symbol2/rithmic simultaneusly once gap its enougth ? 3.- How can I monitor such trades? 4.- How can I close simultaneusly such trades ? 5.- Can I make this in spreadsheet or do I need coding in VC++? Thanks so much for your help. Date Time Of Last Edit: 2015-11-10 01:43:55
[2015-11-10 09:55:45] |
In general what you are asking for is very complicated and if you are asking these questions, we are concerned about your ability to implement this. We cannot provide any specific information. We will only link to the relevant documentation. 1. You will require charts for this. 2. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html 3. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html 4. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html 5. No. You should use ACSIL for reliability. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-11 02:34:40] |
1. We remembered that you can calculate the difference between 2 prices using the Quote Spreadsheet feature. This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_GettingQuotes.html#QuotesOnSpreadsheets You can also perform various other kinds of calculations. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-11 02:35:05
