Date/Time: Wed, 25 Dec 2024 06:16:39 +0000
Request - European (At Least German) Equities with the SC Data Feed
View Count: 919
[2015-11-09 08:17:54] |
Futurestrader77 - Posts: 126 |
I would like to know if the SC Data Feed could contain european (at least german) equities in the future. I am with IB and using the SC data feed since the beginning. It would be really nice to add german equities as well. Thank you! |
[2015-11-09 08:29:31] |
We have sent this request to the vendor of record Barchart to see if they can support this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-09 08:29:49
[2015-11-23 10:27:37] |
Any update? Thank you!
[2015-11-23 10:43:41] |
No update yet. For the time being you will need to use TeleTrader for this market data: https://www.sierrachart.com/index.php?page=doc/TeleTrader.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
