Date/Time: Sat, 23 Nov 2024 04:17:17 +0000
Can't get scale increments figured out on the Bar Time Duration study
View Count: 1501
[2013-06-19 15:54:46] |
MMX - Posts: 119 |
First of all, is it even possible to set scale increments or horizontal grid line increments in this bar time duration study? If so, how is it done? What format do you use for the numbers? Thanks |
[2013-06-19 17:57:45] |
Please refer to the Time Value documentation here: http://www.sierrachart.com/index.php?l=doc/doc_SCDateTime.html#TimeValue In this particular case, the time values are not in integer seconds, however a fraction of 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-19 17:58:25
