Date/Time: Tue, 24 Dec 2024 17:58:44 +0000
last bid x ask column on the DOM
View Count: 1274
[2015-11-08 14:11:36]
User60518 - Posts: 106
hello,
This seems complicated to explain in words but I hope it's understandable
Is it possible to show / implement the last trade prices (in separate DOM columns BID v ASK) at each level until price changes from bid to ask?
by this i mean, for example - if sellers are hitting the bid at .00 and the buyers are hitting the offer at .01 - is it possible to show the accumulated volume at each price in a column on the DOM until the bid turns from offer back to bid / offer turns to bid back to offer at each price?
Say sellers hit bid @.010s - 100, 200, 100 (so will show 400 in bid column 'a'), then 100, 200, 50 buyers hit offer @.01's (so will show 350 in offer column 'b') - resetting if each price goes from bid to offer or offer to bid - does that make sense?? - this would not reset after each price change - just after each price was revisited (if changes from bid/offer or offer/bid)
kind of like a number bar (at each price) but resets when price changes from bid to offer or orrfer to bid
Date Time Of Last Edit: 2015-11-08 14:39:17
[2015-11-10 04:37:54]
We can only refer you to the documentation for the market data columns which are supported in the Chart/Trade DOM:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartDOMColumnDescriptions
There is nothing else available. And definitely no plans for anything else now.
[2015-11-10 04:48:46]
Thanks, the "Recent Bid Volume" and "Recent Ask volume" options are exactly what I was after - prints the volume traded at bid or offer, resetting if the price goes offer (or bid) and vice versa, then turn bid or offer again
Date Time Of Last Edit: 2015-11-10 10:55:16
imageDOM.JPG / V - Attached On 2015-11-10 10:53:12 UTC - Size: 52.91 KB - 330 views
