Date/Time: Tue, 24 Dec 2024 18:15:59 +0000
Enable/disable Strategies
View Count: 734
[2015-11-07 21:23:43] |
AC95711 - Posts: 3 |
To enable/disable strategies, I would like to use a control box as shown below. how can this be done ? Any help is much appreciated. If there is enough interest from other traders, is this something you would consider adding as a standard feature? Chart strat1 strat2 1 on/off on/off 2 on/off on/off |
[2015-11-07 21:51:20] |
We do not know what is meant by "strategy". This term is too vague.
[2015-11-07 22:09:18] |
Spreadsheet System for Trading is what I referred to as strategy
