Date/Time: Tue, 24 Dec 2024 17:47:07 +0000
Problem with alerts
View Count: 1419
[2015-11-07 13:35:18] |
SSS - Posts: 16 |
When I use the Color Background on Alert Condition, why is this formula producing an error: C >= DAILYHIGH[-1] or C >= DAILYLOW[-1] |
[2015-11-08 02:01:09] |
The array operators do not work with the daily high and low values in formulas. Refer to footnote 1 here: https://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#BaseGraphIdentifiers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-08 19:05:03] |
SSS - Posts: 16 |
Thanks, and please bear with me. Why is the following throwing an error: !L = H or !(L=H) Even the example on the documentation page http://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#Operators !(1=2) causes an error. |
[2015-11-08 19:52:15] |
This does not give us an error: !(L=H) What error message do you get? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-08 19:59:47] |
SSS - Posts: 16 |
Alert Formula Error - Chart: FDAXZ5 60 Min #3 | Study: Color Bar Based On Alert Condition | Error: Invalid formula. | Formula: !(10996.500000=11023.500000) | No alert sound/email formula used is: =!(L=H) Date Time Of Last Edit: 2015-11-08 20:00:27
[2015-11-08 20:16:32] |
Does not make much sense. Update Sierra Chart with Help >> Download Prerelease (New Spreadsheets) so you are running the same version we are. Regardless of this though that formula should not give an error. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-08 21:13:20] |
SSS - Posts: 16 |
Just tried on multiple machines and installations, including a friend's. Error DOES appear on all installations we had, all of which are "Old Spreadsheets" versions. With New Spreadsheets versions, including PreRelease version you recommended, the error disappears. |
[2015-11-08 21:19:44] |
OK we are not sure why this happens on Old Spreadsheets but support for Old Spreadsheets is now discontinued.
[2015-11-09 00:00:37] |
We now realize what the problem is. Old Spreadsheets are very Excel specific and compatible. The ! Not operator is not supported: http://www.excelfunctions.net/Excel-Operators.html#ComparisonOperators So the formula has to be coded differently to accomplish what you want when using Old Spreadsheets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-09 00:00:57
