Date/Time: Tue, 24 Dec 2024 17:59:06 +0000
Attachments to Charts/Trading DOM
View Count: 1072
[2015-11-06 09:16:48] |
User842703 - Posts: 55 |
1. Under Global Settings there is a "Customize Chart Drawing Menu" with a list of Config 1-8 menu items available & a few others which I understand is a different item to the Control Bar. However I cant work out how to open a separate drawing tool bar. Please advise and also if its possible to attach it to individual charts. 2. Is there any way to attach the format of the Trading DOM to a chart, in particular the price ladder setting? The Trade Window attachment is the same but the Trading Chart DOM scale varies in increments of 4- 10 points for example on GER30. 3. Regarding the Trading DOM is there any way to remove the mid-price white stamp which covers the current Bid/Ask prices - in certain CFDs the Bid/Ask spread is a consistent 1 point. |
[2015-11-07 03:43:07] |
The response is pending while we work on the documentation for part of this.
[2015-11-10 04:57:23] |
1. The Control Bars/Tool Bars can be customized and attached to the main Sierra Chart window or to any detached Spreadsheet or Chart window. Refer to this page for the relevant documentation: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar 2. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOM 3. No. You will need to adjust the price scale instead to make the numbers further apart: https://www.sierrachart.com/index.php?page=doc/doc_ScalingTheChartDOM.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-10 04:57:59
