Date/Time: Thu, 19 Sep 2024 16:27:55 +0000
limit orders with IB
View Count: 1728
[2013-06-19 14:31:29] |
User48202 - Posts: 10 |
When placing a limit order in SC with IB, dragging the order into position for execution it goes back to the original position for 10 - 15 seconds before returning to execution position. This does not occur with straight IQ feed data.
[2013-06-19 17:03:21] |
Sierra Chart will show the current order price for an order at all times. So if Interactive Brokers takes 10 to 15 seconds to modify an order, then the order will return to its original price until the order modification has been completed by the trading service.
