Date/Time: Tue, 24 Dec 2024 16:26:12 +0000
[User Discussion] - ACSIL - UseTool example to capture 2 clicks
View Count: 1121
[2015-11-06 03:38:02] |
ejtrader - Posts: 688 |
SC Team - Is there any ACSIL example code available to capture 2 clicks or more for an UseTool? For example a retracement / projection - where it would require more than 1 click. Thanks |
[2015-11-06 03:40:27] |
This is marked as a User Discussion. The answer is no and please do not ask us further about this. There is absolutely no way we can keep up at all with all of your requests. It is an impossibility. We will not be responding further. We will frequently mark these kinds of questions as User Discussions. Please understand that and we have nothing further to say. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-06 03:41:30
[2015-11-06 03:50:41] |
SC team - It is understandable. I haven't asked you to provide an example code for this. only was asking whether there is an existing example code available. I understood - you don't have a built-in example code for this. No big deal. I can always get this done by some or other means. Thanks |
