Date/Time: Tue, 24 Dec 2024 16:33:12 +0000
Adding colors to spreasheets
View Count: 789
[2015-11-06 03:19:07]
User314747 - Posts: 7
Is it possible to add colors to SSSFT, for instance a BUY ENTRY would include a green background within column K?
[2015-11-06 09:23:37]
You can only set a fixed background color for a cell or range of cells. This is done through the Spreadsheet >> Cell Properties command.
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetMenu.html
