Date/Time: Tue, 24 Dec 2024 16:05:32 +0000
How to increase the date range shown for a stock.
View Count: 732
[2015-11-06 03:14:54] |
The Stealthy Trader - Posts: 185 |
I noticed that a lot of the stocks that I graph only have data going back to 3/15..as displayed in the Chart Settings box. Not much of a sample size at all. How do I increase that range to like 3/14? |
[2015-11-06 05:06:58] |
Please follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#h42.1 You may also need to change your service package to 3 to get longer-term and more reliable historical data from the Sierra Chart Historical Data service. But not necessarily. It all depends upon the TD Ameritrade system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-06 05:08:00
