Date/Time: Tue, 24 Dec 2024 16:56:21 +0000
Global Profit / Loss Management - Top Step Trader
View Count: 883
[2015-11-05 17:14:20]
User75949 - Posts: 122
I know that Global Profit/Loss management doesn't work on sim.
The point is that it would be very usefull to make it work also on sim especially for the Top Step Trader Combine that is technically run on a sim environment.
Do you plan to make it work in the next future?
[2015-11-05 17:21:52]
The Global Profit/Loss Management feature does work with an external trading service even when you are using a simulated trading account.
So you can use it with Top Step Trader.
It only does not work when Trade >> Trade Simulation Mode On is enabled. You would not be using that with Top Step Trader.
Date Time Of Last Edit: 2015-11-05 17:23:25
[2015-11-05 17:26:05]
are you sure? because once it didn't work to us with Top Step Trader....
[2015-11-05 17:48:01]
Yes absolutely. It will definitely work. Here is the documentation:
http://www.sierrachart.com/index.php?page=doc/doc_GlobalProfitLossManagement.php
