Date/Time: Tue, 24 Dec 2024 17:03:38 +0000
ChartDom and Hand Tool
View Count: 812
[2015-11-05 12:25:39] |
JRA - Posts: 97 |
Is there a setting whenever I have the hand tool enabled and place the mouse over one of the chartdom buy/sell columns only then a horizontal crosshair line to be displayed?
[2015-11-05 17:39:44] |
Global Settings >> Tool Settings >> Chart Values > Always on When Using Other Tools. Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-05 19:36:57] |
JRA - Posts: 97 |
I know about this setting, I was asking if I place the mouse over the columns of the chart Dom only then the croshairline to be visible
[2015-11-05 19:46:50] |
This is not supported like that. You have to activate the Chart Values tool first or have the Chart Values tool always active when using another tool. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
