Date/Time: Sat, 23 Nov 2024 04:39:37 +0000
DLL Warning
View Count: 1489
[2013-06-19 12:14:15]
infpz - Posts: 826
A users is experiencing this when using TTM Indicators - any suggestions?
This custom DLL study has just caused a CPU exception. This custom DLL study may cause ATCharts to be unstable until you remove the study from your chart and restart ATCharts.
[2013-06-19 17:48:42]
While this is not a common issue, sometimes there are minor changes made to the custom study interface which will require a recompile of the study. If this is the case, we mention them on the What's New page here:
https://www.sierrachart.com/index.php?l=doc/new.html
In some cases a Message will be added to the Message Log indicating that a recompile is necessary.
So TTM needs to be contacted and told what particular studies are causing this problem and they should be recompiled. The user will then be provided a new DLL file.
Like we said, this is not common, but there are sometimes some rare cases where this is needed.
