Date/Time: Tue, 24 Dec 2024 16:10:34 +0000
Every Monday Pivot lines missing
View Count: 829
[2015-11-05 05:15:35] |
User486035 - Posts: 9 |
I used one of your indicator. Pivot Points-Variable Period. I set to Days and length = 1. However I found every Monday of week pivot lines are missing. Can you tell me why. I haven't modify any code. It is from the studies Available. Screenshot attached. If you notice the date display at the bottom also is wrong for monday's only. Never displays any of the monday date. Displays only sundays(right after friday) and then Tuesday. Example in the screenshot displays 11-1 right after 10-30. Hence 11-3. skipped the monday display . Could you tell me how to fix. thanks Date Time Of Last Edit: 2015-11-05 05:27:34
Pivot_Missing.JPG / V - Attached On 2015-11-05 05:13:57 UTC - Size: 268.01 KB - 278 views ChartSetting.JPG / V - Attached On 2015-11-05 05:27:25 UTC - Size: 90.93 KB - 281 views |
[2015-11-05 18:14:03] |
Based on the Chart Settings there are very little bars for Sunday so there is not enough room for the Date label for Monday. In the Pivot Points-Variable Period study, set Auto Skip Period of No Trading to Yes. This will solve the problem. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_PivotPoints.html#s223 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-05 18:15:21
[2015-11-05 22:13:14] |
Sweet like sugar. Can't helpa
