Date/Time: Tue, 24 Dec 2024 13:59:39 +0000
Order of symbols in a Watchlist
View Count: 942
[2015-11-04 12:04:16] |
User842703 - Posts: 55 |
Is there any way to have a linked watchlist/quoteboard where the order of the symbols can be manually changed? I've found the Associated Watchlist function but that does not allow to insert any information other than the symbol.
[2015-11-04 17:45:43] |
Yes. In the Quote Board you can change the order of the symbols through Settings >> Set Symbols. You can move them up and down. Here is the documentation for the Quote Board: https://www.sierrachart.com/index.php?page=doc/doc_GettingQuotes.html#QuoteBoard Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-04 17:46:01
