Date/Time: Tue, 24 Dec 2024 12:53:49 +0000
Start study at session
View Count: 980
[2015-11-03 16:46:06]
User832215 - Posts: 27
Hi, is there a way to make each study restart at session start? I want to know how to make my moving averages restart every session like the VWAP does
[2015-11-03 16:58:09]
No. However, a Moving Average already does restart each and every single bar. It is not cumulative calculation.
Date Time Of Last Edit: 2015-11-03 16:58:47
[2015-11-03 17:10:12]
Ok maybe I wasn't clear with what i meant with "restart at session start". Specifically I don't want my moving average to use the last day's bars in the calculation. If I have a simple moving average (20) and at start of the session there has only been 1 bar created which closed at 2000, then the value of the MA should be 2000. As it is now the first bar of the session and the 19 bars before that will be in the calculation. Is it possible to do that?
[2015-11-03 17:37:56]
You will need to create your own custom study to do this. Refer to these pages here:
https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html
https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html
