Date/Time: Tue, 24 Dec 2024 14:13:04 +0000
quick way to change symbol for all charts in chartbook?
View Count: 3246
[2015-11-03 16:29:45] |
User60518 - Posts: 106 |
Hi is there a way to apply a new symbol to all charts in a chartbook? for example I have a number of charts/windows for CL (CLZ5)- if I want the same charts for the DAX - can I set change the symbol for all charts in the chartbook in one move? |
[2015-11-03 17:46:41] |
Use the Chart Linking feature: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartLinking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-03 19:24:09] |
ejtrader - Posts: 688 |
Would be nice if you could some how allow "Trade and Current Quote Symbol" as well to be replaced in a chartbook by some means rather than going through all the charts to replace it. thanks |
[2015-11-03 19:52:43] |
That symbol can now be set in the Global Settings >> Symbol Settings for a particular Symbol.
[2015-11-03 20:01:21] |
Thanks and good to know. However unable to figure out how to define this for a remote service ( if supported ) under global settings >> symbol settings. Is it the underlying symbol on the local copy or something else on the remote copy? thanks |
