Date/Time: Sat, 23 Nov 2024 05:19:25 +0000
Not saving chartbook properly
View Count: 1490
[2013-06-19 10:04:55] |
EuropeanTrader - Posts: 290 |
Hi, I arranged my view as attached but when I relogin it crashes every time. How can I make sure it stays saved? thank you. |
Attachment Deleted. ScreenHunter_89 Jun. 19 12.04.jpg / V - Attached On 2013-06-19 10:04:33 UTC - Size: 184.66 KB - 537 views ScreenHunter_89 Jun. 19 12.02.jpg / V - Attached On 2013-06-19 10:04:50 UTC - Size: 213.7 KB - 544 views |
[2013-06-19 10:07:36] |
What is meant by "crashes"?
[2013-06-19 10:40:19] |
hi. i am sorry, maybe a used to strong of a word. I align two watchlists side by side and put a chart in the middle. but when I restart sierra the watchlists are no longer as I left them thx |
[2013-06-19 10:42:11] |
Could you provide your Chartbook with this configuration so we can test it. These are the instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-20 12:27:17] |
sure, attached thanks! |
korelacije.cht - Attached On 2013-06-20 12:27:09 UTC - Size: 48.66 KB - 582 views |
[2013-06-21 01:29:57] |
This will be resolved in the next release. Surprising this has not been brought to our attention earlier. We had thought when the Chartbook is saved, the Associated Watch List window positions are saved.
