Date/Time: Tue, 24 Dec 2024 03:05:26 +0000
Acount question
View Count: 693
[2015-11-02 13:48:15] |
User60518 - Posts: 106 |
Hi - my account is currently set up for use with topsteptrader. If I wanted to install a second instance of Sierra Chart on my PC can I use this version with my transact data feed? When I check the data/trade service settings it states Transact is not available in this package. (ps) I wont be running these at the same time. Thanks Date Time Of Last Edit: 2015-11-02 13:50:57
[2015-11-02 16:37:59] |
Sierra Chart - Max - Posts: 5758 |
Your Sierra Chart account has been updated to enable all services. Please restart Sierra Chart. You can install Sierra Chart on as many computers as you want, but you can only run it on 2 concurrently. On the same computer you can run as many instances as you need. Let us know if you need help installing another instance of Sierra Chart on your computer. Sierra Chart Support Date Time Of Last Edit: 2015-11-02 16:40:03
