Date/Time: Tue, 24 Dec 2024 02:35:17 +0000
[Locked] - Notice: New Interactive Brokers EUREX DAX Symbol Format
View Count: 4248
[2015-11-02 05:36:58] |
Due to new specification requirements by Interactive Brokers, the symbol format has changed for the EUREX DAX futures. Follow the instructions here to update the Symbol Settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Use this new symbol format you will find in File >> Find Symbol >> Futures: DAX-######-DTB-EUR-25 You can change the symbol of existing charts through Chart >> Chart Settings >> Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-02 05:54:32
