Date/Time: Sat, 23 Nov 2024 04:28:44 +0000
Cumulative Delta Bars - Volume
View Count: 1440
[2013-06-19 04:41:18] |
User28682 - Posts: 233 |
How come the cumulative delta bars-volume study resets to "0" at 12:00 est every nite? This is really annoying. I didnt think it was doing this months ago? Is this a bug, or a setting issue? Thanks Tom |
[2013-06-19 05:05:52] |
There is a setting for this in the Input settings for the study. You can set it to Yes or No.
