Date/Time: Tue, 24 Dec 2024 13:40:59 +0000
[User Discussion] - Volume per second
View Count: 1482
[2015-11-01 06:58:06]
KhaosTrader - Posts: 128
I want to make a relative volume study for tick/range charts. To accomplish this I believe i would need to construct an array which would hold volume data for each second. Then I can compare prior bars to the current bars by looking at the relative volume for the seconds that were composed of the tick/volume bar.
Can you point me in the right direction for figuring out how to get this one second volume data in a range chart and/or tick chart?
Thank you in advance...
[2015-11-03 18:21:03]
Hi, please let me know when you can answer this question, as I want to write this volume study...
Thank you.
[2015-11-03 18:27:08]
This is not within the scope of our support and has been marked as a User Discussion. We do not provide programming help. Refer to our support policy here:
https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#GeneralInformation
Date Time Of Last Edit: 2015-11-03 18:27:41
[2015-11-03 18:54:36]
Apologies. I will research this and work on it, and if I have a specific question, I will ask it... upon reflection, I agree with your feelings regarding my question, I see its way to broad...
