Date/Time: Tue, 24 Dec 2024 03:05:07 +0000
OHLC / Settelement of previous day problem
View Count: 900
[2015-10-30 16:00:24] |
wwwingman - Posts: 185 |
Hi I am trying to draw the *previous* day settlement on a *current* day of an intraday chart, using the Daily OHLC study. I a know many asked similar questions, have read the study and settlement/last trade documentation, but simply cannot set it right. My charts : * #1 Intra-day main chart (60mn), globex session time set to the daily session, with week end data, no night session. * #2 Historical daily chart. Both with 20 days data. Daily OHLC is set on chart #1 with : * Use This intraday chart to No * Daily Chart # to 2 * Reference Days Back is set to 1. Result : nothing is drawn. FWIW : * When Reference Days Back is set to 0, the levels of the *current* day are drawn. But I want the previous day, not the current day... Please advise. -- W. |
[2015-10-30 17:04:53] |
Sierra Chart - Max - Posts: 5758 |
Set the Scale for the Daily OHLC Study to Automatic. Refer to the instructions here on how to get to the Scale window of the study: http://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindowStudy This will cause the scale of the chart to automatically update to insure that previous day settlement amount is visible. Sierra Chart Support |
[2015-10-30 17:31:17] |
Scale set to automatic. Still nothing drawn. Please remember I indicated that when Reference Days Back is set to 0, the levels are drawn so it is not a scale pb. -- W. Date Time Of Last Edit: 2015-10-30 17:32:18
[2015-10-30 17:40:38] |
There must be some problem with the study settings, or with the data. We do not observe any problem with this. Attach a Chartbook containing these two charts only by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-30 17:41:03
[2015-10-30 17:54:59] |
Thank you for your answer. Enclosed-by the chartbook describing the problem. FWIW : My feed is IQFeed and I don't seem to see problems on my other charts/charbooks. -- W. |
OHLCPb.cht - Attached On 2015-10-30 17:53:12 UTC - Size: 49.61 KB - 351 views |
[2015-10-30 20:40:08] |
We see what the problem is and we are solving this. It has to do with how the Session Times are set in the chart even though it is a Historical Daily chart.
[2015-10-31 19:07:10] |
This means a temporary solution for my problem is to change the session time of the daily chart to 00:00 - 23:59 (switch to intraday.. set the session time.. switch back to historical daily). -- W. |
[2015-10-31 19:24:57] |
Yes.
