Date/Time: Sat, 23 Nov 2024 04:31:37 +0000
gold chart problems
View Count: 1397
[2013-06-18 23:49:46] |
M5amhan - Posts: 468 |
Im sorry to keep bothering you about this gold data but I think there may be a problem from the data provider. This is the third time within a week incorrect data has plotted on the day. The bar from 06-12-13 never got fixed either. It is only gold doing this. The chart below shows both bars that are incorrect. (06-12-13 & 06-18-13) http://www.sierrachart.com/image.php?l=1371598999808.png Could something please be done so this stops? Thanks |
[2013-06-18 23:59:54] |
We will let them know.
