Date/Time: Tue, 24 Dec 2024 02:52:26 +0000
custom study
View Count: 925
[2015-10-30 02:50:47] |
User89188 - Posts: 20 |
I had a previous question about opening a custom study.i got an error.here is what it says
Attachment Deleted. ofett22.png / V - Attached On 2015-10-30 02:50:23 UTC - Size: 95.77 KB - 338 views newtt2.png / V - Attached On 2015-10-30 02:50:42 UTC - Size: 19.91 KB - 337 views |
[2015-10-30 02:51:41] |
how can I fix it.the developer says everyone else at sierra can open it except me.so the issue is on my end
[2015-10-30 04:13:27] |
We are contacting the developer about this. Some of those errors relating to sc.FreeDLL needing to be set to 0, will be solved when you update Sierra Chart with Help >> Download Prerelease. Please do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
