Date/Time: Sat, 23 Nov 2024 04:33:52 +0000
Chart Screenshots
View Count: 3610
[2013-06-18 22:29:25] |
AL324 - Posts: 7 |
Hi, I have two questions about saving charts/ chart screenshots: Is it possible to save screenshots as .jpg? Is it possible to specify the filename and location when saving a screenshot? Thanks! |
[2013-06-18 22:53:59] |
The answer is no to both of these. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Image_to_Server.html#Local Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-18 23:18:26] |
AL324 - Posts: 7 |
Are either of these functions able to be implemented by user programming or are they on your end only? |
[2013-06-18 23:59:22] |
It is not possible to change this with user programming but you can always programmatically copy the files from the Images folder and change the names.
