Date/Time: Tue, 24 Dec 2024 03:24:28 +0000
problem
View Count: 707
[2015-10-29 19:50:08]
User367236 - Posts: 2
i can not put volume on my charts when i try to i need to double click then the volume appears. In the past i would click on the draw volume profile and i would use my curser and draw a square then click my curser and volume would appear. now i can not do that and i also noticed that there is a check next to volume profile and also next to erase all drawn volume profile what do i do
[2015-10-29 19:54:10]
Update Sierra Chart to the current version by following these instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
You should not have either of these problems in the current version.
