Date/Time: Tue, 24 Dec 2024 03:21:20 +0000
Global Profit/Loss Management
View Count: 730
[2015-10-29 18:05:16] |
User57210 - Posts: 121 |
I would like to use this functionality, but it appears the buttons/options/checkboxes are not accurately represented by your written information on the subject. Please advise. The only function listed on my SC Software in Global Settings is called "Global Profit Management". Can this be used for loss limit management simply by using negative triggers and such? |
[2015-10-29 18:31:32] |
You need to update Sierra Chart to the current version. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
