Date/Time: Tue, 24 Dec 2024 02:57:54 +0000
Mini Dax Symbol On IQFeed
View Count: 2013
[2015-10-29 16:19:58]
JRA - Posts: 97
IQfeed Mini Dax Symbol is DXM, I updated the symbols as you suggest in other threads but I don't see it on IQFeed symbol list. Should I do something else to add it?
[2015-10-29 16:47:03]
Sierra Chart - Max - Posts: 5758
The MINI Dax has been added to the DTN IQ Feed symbols list.
You need to update your Symbol Settings following the steps here:
http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
And then you will have the Mini DAX in the Available Symbols list under File >> Find Symbol.
Sierra Chart Support
Date Time Of Last Edit: 2015-10-29 17:10:02
