Date/Time: Tue, 24 Dec 2024 03:14:37 +0000
Wandering moving average on CCI overlay
View Count: 869
[2015-10-29 08:29:26] |
User40520 - Posts: 62 |
When I overlay a moving average on CCI it works perfectly but if I use a different indicator like MACD and then overlay the same CCI with the moving average CCI (set up exactly as before) the moving average at times will lose its reference to the CCI. It seems the MACD interferes with the CCI moving average Is there a way to resolve this problem? |
[2015-10-29 09:12:29] |
Follow the instructions here for this: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#MaintainingSameScaleForMultipleGraphsInChartRegion Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
